  • Have a Problem with the Courtesy Blinkers
    Posted by Davy on February 4, 2012 at 10:12 pm
    You guys are batting 100% so far on everything I have ask. I have confidence that you will knock this one down too.
    This problem cropped up within the first year I owned the bus and after calling the bus guys I knew and Featherlite (That was a learning experience) I put it on the back burner. Now that I have you all as a resource I am curious and motivated again.
    When I wanted to say “thanks” to a trucker for letting me in I could flash the clearance lights with a switch on the end of turn signal handle. One day that just quit.
    Also, when I turned the key on and prepared to start the bus there was an audible two toned chime. That chime stopped the same day.
    Are these things related? I was told to check the relay’s in the compartment outside under the driver’s window but couldn’t find anything on that list.
    Any ideas or answers?
    Thanks,
    DKO
    Archived replied 14 years, 9 months ago 2 Members · 1 Reply
  • 1 Reply
    February 5, 2012 at 6:36 am
    I would start here: http://prevostparts.volvo.com/technicalpublications/en/manuel.asp
    From here you can find the wiring diagram specific to your coach. It is a little tricky at first trying to learn the ropes sorting out diagrams but once you get to what you want you can always keep going back to the ones for your serial number.
    There is a relay for the courtesy lights because I had to replace one on my previous coach, but I am not aware of a chime so that may be a Vantare addition.
