  • Hart inverter question
    Posted by Bill on August 31, 2021 at 10:13 pm
    Occasionally the amps number indicator when running my generator blinks rather than a steady light. What does that mean?
    Dick replied 5 years, 2 months ago 3 Members · 2 Replies
    September 1, 2021 at 4:56 pm
    Little different scenario but my #2 inverter does that when on battery power and using microwave.
    September 1, 2021 at 8:20 pm
    My Bus is a 92 with 2 Heart Inverters, I see this case when the battery voltage drops below13 volts. Using lots of amps from the inverters like a hair dryer will drop the voltages enough to turn the light off. If you continue pulling the amps thru the inverters the orange then red light will come on if the voltage drops low enough.
