H3-45 Window stile lights
Posted by Dorel on August 17, 2015 at 6:26 amHello, where do I find the salon window stile lights(12v) breaker / fuse to reset / change? Thanks
Fred replied 11 years, 2 months ago 6 Members · 9 Replies -
Location in a fuse block right front corner inside bus. If you peek inside seeing a small red light on ,
that fuse is defective.
Thanks Al, please review the photo, let me know which one are we talking about, White arrows or Red? If red, do I have to remove power to access or just remove cover and replace 7.5Amp fuse? If remove power is suggested, where do I do it?
White arrows…it looks like there is a red light “on” in fuse block by lower left white arrow .
Also, behind the access door wall to cruise air another fuse block.
Question….Do your fairy lights in hand holds work ?
I know this is frustrating but keep in mind our buses are only 30 apart and both with OTR air.
So you think they would be the same ?
Could be similar but changes took place on every bus and the most common problem is where they decided to mount things.
I don’t believe we need to remove power…this should be a fuse issue. I like the idea Marathon uses when a fuse blows a red light goes on. Had one adventure where the red light was not working.
I have a high tech $.99 cent magnifying glass in my tool box…which as I age I’am using more often.
Al, the red light on the 10amp lower RH is just a light reflection. If i replace any of these fuses, there is a beep coming from the box arrow orange and lights still do not work.
Handle lights are working intermitentl.
The box at the orange arrow is your Techlink computer and your light problem could be with Techlink. The Node Relays with the fuses are marked on the front with the corresponding function. I have had a red light before and the fuse was good. Have you tried a re-boot to see if Techlink will fix it? I cut the 12 and 24 house power to Re-boot.
Tom, 10AMP fuse in the bottom was not red, I replace it, no change.
Fuse block cover is marked with “Salon/Galley stile Lts”, I will remove cover
and replace OUT 3 fuse with 7.5Amp fuse and test again. -
Sorry, just got back home.
I’ll go out to our bus Tuesday and locate the fuse I replaced. I believe it was more to right of your picture in another fuse block.
