    January 20, 2012 at 7:00 am
    I let the coach sit since Saturday with the input fuel to the filter cut off. I turned on the valve last night and the coach fired up and ran great! When I shut it down I closed the valve again so it will be ready for next time. I guess that pretty much proves the check valve in the Racor is bad. Now all I have to do is order the parts and replace it.
    Thanks for all your help with this!!!
    February 3, 2012 at 6:49 am
    Just as a followup, I replaced the check valve in the Racor filter on Saturday. I left the fuel cutoff turned on and the coach started on half a turn last night after sitting for 5 days. Hopefully that problem is solved with the check valve.
    Thanks for all the help!!
Page 2 of 2
