  • H-3 Awning Window help
    Posted by Rick on September 14, 2020 at 5:13 pm
    My ’08 Marathon H-3 awning window, sounds like it needs some help. The window locks and unlocks and The motor turns but the window doesn’t move. It sounds like something is stripped or not connected. Before I pulled it apart, I figured someone had the same problem.
    Marshall replied 6 years, 2 months ago 5 Members · 6 Replies
    September 14, 2020 at 6:19 pm
    I worked on a 2000 x Country Coach it had simular problem motor turned spiral screw that raises window had pin sheared wouldened raise window
    September 14, 2020 at 7:14 pm
    Bernie will probably jump in here Rick, my 04 had manual sliders.
  • Marshall
    September 14, 2020 at 7:20 pm
    Rick
    There’s 2 things it could be. You need to unscrew the inspection plate on the inside bottom of the window so you can see the motor and rod and report back with what it’s doing.
    You will better understand once you see the inside. Inspect the set screw.
    Later
    bv
  • Eric
    September 14, 2020 at 7:59 pm
    Got it…..I’ll report back
    September 15, 2020 at 3:59 pm
    Bernie, figured it out. Motor shaft Allen key was loose inside of window
    thank’s
  • Marshall
    September 15, 2020 at 4:26 pm
    ok good, glad you didn’t have to drill a new hole.
    Later
    bv
