  • Green LED light beside breaker not as bright as b4
    Posted by Robert on November 15, 2013 at 5:56 pm
    In the process of changing the GFI outlets finnally got the new outlets to reset but the green LED light beside the breaker is not as bright as before but it is on
    Bob replied 12 years, 12 months ago 2 Members · 1 Reply
  • 1 Reply
    November 16, 2013 at 6:28 am
    The two are unrelated. Even if you disconnect the GFI and then turn on the circuit the light will be the same. One way to check it is to trip the GFI. That interrupts power to the outlets which is the same as removing the GFI.
