  • Got any ideas on entry door lock?
    Posted by Mike on August 15, 2014 at 8:27 pm
    Right now the coach has the original air lock and key to lock and unlock. Problem is ….. I like the air lock but after the air leaks down in a couple days I have to slam the door several times to lock the coach. I know I can remove the air lock and install a regular RV lock on the door. Only problem is I don’t want to lose the air tight seal on the door and have road noise. Any suggestions? Thanks! Mike
    AL replied 11 years, 4 months ago 15 Members · 26 Replies
  • 26 Replies
  • Ken
    August 15, 2014 at 8:34 pm
    Mike, fix the air leaks ?
    August 15, 2014 at 10:09 pm
    Mine has the air lock that pulls the door in tight when air
    pressure is in the tanks. It also has a home style dead bolt on the
    door. My air pressure leaks down after a day or two. The dead bolt is
    great for security when parked. I really don’t need the the pull in
    feature when parked so it doesn’t matter if the air leaks off, that is
    unless I’m parked in a hurricane or tornado. When I start driving, I have air pressure of course, I hit
    the lock switch and the door pulls in tight.
    Corey and George, you like Robert Earl Keen or Joe Ely’s version better?
    Ken
    August 16, 2014 at 12:10 am
    I had a 1997 with house dead bolt and air lock it would lose air and be open in morning , I fixed all air leaks replaced all fitings with comp fittings in whole coach and air lock would stay locked for weeks if not months the bimba valve that locks door may have push in fittings on it , it can leak , I put ball valve on line in steering compartment to check it and it stayed locked for one month , I would say fix all leaks , hope that helps , I also replaced the bimba valve with new one also it can leak when it’s old
    August 16, 2014 at 3:04 am
    The air lock is only for driving, If your trying to close the door with the air lock on it is difficult. I remember one morning and my son in law was slamming the door. He went out without unlocking the air lock and but could not get the door to close. that was the last time I used the air lock while parked.
    August 16, 2014 at 7:37 am
    Just go a heavy duty striker bolt design like in my 98 entertainer, Works just like a car door-only requires one hand to operate.. Mine also has deadbolt assembly. Parts from prevost. Bob
    August 16, 2014 at 8:06 am
    Thanks everyone for the ideas! I will try to fix the air leaks and install a deadbolt or check with Prevost about the door lock assembly Bob is talking about. Where is the bimba valve located and how do you turn off the air to the air lock? Thanks! Mike
  • Raymond
    August 16, 2014 at 8:56 am
    The valve on my 1997 was right behind the locking pin and I put ball valve in steering bay, just find air line going to valve and put one in
  • Ronald
    August 16, 2014 at 9:26 am
    Ken, I actually like Steve Earles version the best. I’ll ask Corey which one he likes. Geo.
  • Rick & Denise
    January 5, 2015 at 9:05 pm
    I ordered a new interior lever for my 1991 when I got the little tab and looked at the price I sent it back. Over a $100.
    January 6, 2015 at 7:56 pm
    my air lock is locked by a switch on the dash ,, are you able to operate from outside the coach
  • Tom
    January 6, 2015 at 8:18 pm
    No you can’t only from inside
    January 10, 2015 at 10:45 am
    David – Yes, I have a push button on the outside and a lock cylinder. Works great when there is air in the system. But the air lock is connected with the rest of the air system and after opening and closing the door during the day the air depleats and I have to crank the bus up to refill the air tanks. In normal use, the door air will last about a day and a half.
    January 10, 2015 at 11:28 am
    Sorry mike forgot yours was a seated coach first my fault
    January 10, 2015 at 12:11 pm
    small one hooked to line going to air lock with a check valve on bus air supply side. Should give you service if you are air tight from delivery side to cylinder. I hooked mine on old coach that way. IT lasted for days depending on how much you use door. If it is air tight in thoery it would last forever. was talking about a small 8 inch by 14 inch air tank. Bob
  • Dale
    July 6, 2015 at 9:27 am
    I always loved the air lock on the door. But as said, it is mostly for pulling the door tight while going down the road…
    I found out something recently that I didn’t know. I was working on my bus when I was having the trans problem. So I turned off the batteries and let the coach sit for a while. I can’t even tell how it happened, but at one point I went back to turn the batteries back on and when I went to go back into the bus I was locked out – by the airlock! Freaked me out. I was on the side of the road and locked out of my bus! After a brief moment of panic, I went back and turned the batteries back off, and went and the door opened. Not sure how it happens, but at least on my bus, the air lock is somehow tied into the electrical system. So even if you don’t have air leaks, this would make it an ineffective overnight lock if someone were to figure out to turn the batteries off. Try it on your coach and let me know if yours is the same. Have someone air lock it from the inside and then go shut the batteries off and see if the door opens.
