  • Gnerator Overheating
    Posted by Mike on May 3, 2020 at 12:15 pm
    Hi Guys, I have a 99 Royale with a 17.5 Power Tech generator and it is overheating. I went through several trouble shooting steps recommended by all you experienced prevost owners and got to the problem by removing the radiator. Sure enough, the big squirrel cage fan is not working. Should I check capacitor, then the fan itself next? Also I think I read that the fan should run immediately when Generator is started. Is this true?
    Thanks!
    Ya’ll are a wonderful asset to all Prevost Owners!
    Mike
    Archived replied 6 years, 5 months ago 9 Members · 12 Replies
  • 12 Replies
    May 3, 2020 at 2:02 pm
    I am not familiar with Royale, but my Liberty radiator fan runs as soon as the generator is producing current.
  • Chuck & Katrina
    May 3, 2020 at 2:31 pm
    x2 what Jon said. Make sure the fan motor is getting 120v before writing it off.
    Leesburg, FL
  • George
    May 3, 2020 at 2:32 pm
    You may have a breaker on the gen panel for the squirrel cage fan.
  • George
    May 3, 2020 at 7:12 pm
    I had that happen to my Royale, It was the start capacitor for the fan that was bad.
    May 3, 2020 at 11:04 pm
    Mine did the same thing and it was the start capacitor on the fan motor. replaced it and all is well.
    m
    May 5, 2020 at 8:21 pm
    Thanks Guys, that was it the capacitor!
    May 6, 2020 at 9:27 am
    Is the start capacitor on the motor? or remotely mounted?
    May 6, 2020 at 12:08 pm
    On my Royale, it was remote mounted. Did not have to remove the radiator to get to it. I don’t remember the exact location, but it was close to the motor.
  • David
    May 11, 2020 at 6:06 pm
    Hello, Figure i would jump on this thread . My generator overheated but did not shut down . Instead after seeing steam we shut her down . Upon opening the area I saw the radiator cap had blown off the tank damaging the tank itself . Any idea on whet happened here would be appreciated .
    Well I finally checked into a campground and removed the Tank . Seems the weld on the tank just gave way . So this week I will take the tank to a radiator shop for opinion and repair . The cap is 13 lb so I will check the specs and replace with same or lower pressure .
  • Chuck & Katrina
    May 19, 2020 at 8:21 am
    Mine is in the generator bay to the right. Mounted on the bay wall between the generator and radiator bay in a electrical box. No need to remove radiator.
    Leesburg, FL
  • Deleted User
    Deleted User
    June 28, 2020 at 11:12 am
    Generator running with all 3 cruiseairs on 95 degree day. started to smell the “burning insulation” turned off one ac and it got better. Once home, I removed the radiator compartment doors located passenger side bay one on the 1997 Marathon. Checked operation of the centrifugal fan as well as the two electric fans mounted on the radiator face. all ok. Went to find the exhaust path for the centrifugal fan that pushes air into the generator side. found a tall narrow slot on forward side of the wall but no outlet. Kept looking and found that the original sound deadining foam has broken down and totally covered the bottom of this slot which had screen material at the bottom where the air is supposed to vent down! There was little to no airflow in that generator bay.
    June 28, 2020 at 12:39 pm
    Remodeled our generator and gen radiator compartments. Here is a thread on each job:
    Gen Comp LINK
    Rad Comp LINK
