  • Generator wont start !
    Posted by doris on June 4, 2017 at 12:55 pm
    1990 Marathon prevost XL, Martin generator, never had a problem but after my last shut down of the generator it wont start again! Neither of controls work, front back and on the gen itself, not even a click?
    Archived replied 9 years, 5 months ago 10 Members · 16 Replies
  • 16 Replies
  • Doug
    June 4, 2017 at 3:27 pm
    battery voltage is step one….can you post picture of gen. Yours has the separate start/stop switch directly on it?
    June 4, 2017 at 4:17 pm
    Moved for Andre.
    Start checking at the battery for battery voltage and tight cable connections. Follow the battery ground wire from the battery to where ever it goes and make sure it is a tight well grounded connection. Do the same thing with the postive cable, start at the battery and follow it to the starter. Make sure all connections are tight. Check the smaller wires on the starter solanoid and make sure the are tight. Sounds like either a dead start battery or a connection has come loose some where.
    Check all the easy simple stuff first, before getting to worried.
    Andre & Ann 2001 Liberty H345 no slides
    78,000 miles
    2014 4 DR JEEP RUBICON
  • Harry
    June 4, 2017 at 5:12 pm
    We have experienced this exact same issue before. By toggling the generator power button (above driver) on and off a couple of times it should work. Ours sticks sometimes.
    June 4, 2017 at 5:20 pm
    Thanks has the start option on the generator, when dc power is on starter has power on. No power to the start togle switch, starter works when bridged with screwdriver but doesnt run, batteries are new.
  • doris
    June 4, 2017 at 5:25 pm
    Thanks all connections are tight batterie ok, gets power to the main starter wire when dc power is on! No power on the togle switch. Starter will work with conecting big wire to small wir with screw driver but doent run that way ?
    June 4, 2017 at 5:26 pm
    Thanks tried but no sigar!
  • doris
    June 4, 2017 at 5:32 pm
    I tried on all 3 possible generator start buttons none work!
  • Gary
    June 4, 2017 at 5:33 pm
    Love my 1990 bus, sounds you own the same?
    June 4, 2017 at 5:58 pm
    You’re getting lots of great advice from some pretty smart and very experienced people.
    Consider calling Jim Martin at Martin Generators:419-782-9911
    Jim@MartinDiesel.com
    I met him at the PRI show in Indianapolis last December. Even though we have a Wisconsin birthed Kohler in our coach I found him to be very engaging and very knowledgeable. I should be another good source of ideas for you.
    I wish Martin Generators was an advertiser on this web site and their staff monitored the postings.
    June 4, 2017 at 7:18 pm
    On our coach the “GEN DC PWR” button sticks just enough to remind us who’s in charge. Cycling it a few times and all is good. I tried attaching a photo.
  • Roscoeapproved
    June 4, 2017 at 7:19 pm
    If you open up the main control box the start signal is actually a ground signal. While pushing one of the start switches make sure you are getting a momentary ground pulse on pin 1,9. The stop signal is also a momentary ground pulse.
    Jeff and Lindsay
    91 Marathon XL
  • Walter
    June 4, 2017 at 7:36 pm
    pin 1 or 9 should have continuity to ground normally. When you push start it ties the other one 1 or 9 to pin 2 which is ground. You can try jumping 1 to 2 or 9 to 2.
    June 4, 2017 at 7:50 pm
    I sent you 3 pages of wiring diagrams via email if you do not already have them. I would post them on here but I do not know how to post a Pdf file.(admin help?) Others may be able to help further if I could post them. Let us know how it goes. Jeff
    June 5, 2017 at 2:57 pm
    Thanks that would be great hugoreverse@yahoo.com
    June 5, 2017 at 6:09 pm
    sent..past tense. I sent them yesterday to the email linked to your screen name. Jeff
