  • Generator removal
    Posted by Reagan on August 20, 2016 at 1:14 pm
    The 17.5 Power Tech Kubota is installed “length-ways” in our bay and I have a radiator hose leaking from the back side of the engine….only one side of the hose can be accessed…..the other side is against the back side of the bay and cannot be reached except by Spiderman…. I assume removal of the generator is essential and it is not on a slide. The hose cannot be reached from the other side of the coach via the access provided.
    Anyone with any experiences like this? Any thoughts please?
    Pres
    JIM replied 10 years, 3 months ago 8 Members · 11 Replies
  • 11 Replies
    August 20, 2016 at 2:45 pm
    That’s one downside to the way CC did their gens instead of a slide out. It will likely have to come out and best option is to have a forklift available. I know over the years I’ve heard removing the gen isn’t that big a deal, so hope it goes easy for you.
    August 20, 2016 at 3:56 pm
    Pres,
    If you are going to pull the radiator yourself, as a solo worker having handled a lot of very heavy stuff on my coach myself I don’t have any fear about doing the removal, but do make sure if you opt to do it you have a solid game plan.
    I have seen the installation you describe and once you have the generator unsecured you would be amazed how easy it is to work the generator out onto a 2X6 platform using nothing more than levers, or small rollers like the olden days of using plank and rollers to move very heavy oblects. The key is to take your time, don’t leave anything to chance, and take advantage of the fact you can raise and lower and tip the coach to get it to do a lot of the work for you.
    I have used a very small 500# capacity motor cycle jack to move my water and holding tanks around, I have moved my complete entertainment center on a creeper with 4X4 blocks to build it up to the correct height, and I have used a rolling work cart to get my alternator to the right height to slide the old one out and the new one in. For my 170# batteries I just make slides out of 2X6 planks and push and pull them. My point is that there is no need to use brute strength and the job is greatly simplified if you use levers, short sections of small diameter round rod or pipe, a come-along, or even an application of grrease to make stuff slide.
    If you opt to have someone with a fork truck do the job just remember they can do a lot of damage pretty quick if they are a little careless so I would watch them like a hawk and stop them the moment I felt uncomfortable.
    August 20, 2016 at 5:16 pm
    Thanks for the guidance… I plan to have a mechanic do this job. I will have a proper lift or fork lift available. It was so stupid for the installation to have been done like this. The rest of the coach has been so great….
    Best,
    Pres
  • victor
    August 20, 2016 at 5:44 pm
    Pres, just wondering, would now be a good time to install a sliding tray? Is there enough room?
    Good luck on your project.
  • Michael
    August 20, 2016 at 7:33 pm
    Pres,
    My 2002 CC is on a slide. If possible add one while your gen is out. It makes everything so easy I actually enjoy servicing my unit. My 6’4″ 250lb frame can even (uncomfortably) get to the battery and the remote radiator.
    August 21, 2016 at 3:19 pm
    George shot him a photo of your slide. Sound like he is going to have to have custom one made, but well worth it.
    August 22, 2016 at 10:30 am
    I am very interested in making a slide..
    This is crazy.
    Pres
  • Tom
    August 22, 2016 at 11:20 am
    Making a slide is on half of the equation.
    The bays have a plywood floor and some structure at the perimeter, but not necessarily where a slide will be secured to or through the floor.
    It would be a good idea to insure that when the weight of the generator is cantilevered out from the bay opening the rear part of the slide supporting it has an attachment through the floor into some wieght distributing devices or structure. Depending on how far out the generator will slide will determine the amount of force the rear slide attachment bolts or fasteners have to carry. It is going to be substantial.
    August 22, 2016 at 2:54 pm
    Thank you again.The beat goes on.
    Pres
    August 22, 2016 at 9:37 pm
    Pres,
    I’m happy to shoot some pictures for you . We have the same generator so maybe they will be helpful. In addition to what everyone has suggested the power and water lines to the remote radiator have to have slack to extend. It may be Friday before I can do the pictures. If that’s not soon enough to help let me know and I will try to reschedule some things.
  • JIM
    August 22, 2016 at 10:28 pm
    Whenever you can get the pictures, it would be appreciated.
    my email is rsirmons@comcast.net if that makes it easier.
    Pres
