  • Sid
    July 29, 2014 at 10:39 pm
    Tom, it is the original gen in 2000 Vantare XL
  • Eric
    July 30, 2014 at 1:04 pm
    My 20KW Powertech runs around 38psi hot. I called the manufacturer last year as well and they stated the same thing to me that pressure anywhere from I believe 12 to 60psi hot is perfectly fine. They also said changing oil every 200 or so hours is also fine. I do have the Kubota engine.
    July 30, 2014 at 7:29 pm
    Tthe reason I asked Larry is if it has 38 hrs. that doesn’t add up since the coach is 14 years old. I suspect you could have a high hour gen that has the hour meter changed out. All it takes is a few screws and several wires to replace with a new hour meter.
    Am I missing something?
    July 31, 2014 at 7:04 am
    No Tom, it is the original gen and the hours are correct. The bus only has 49,000 miles on it. It was used very little. It wasn’t cooked in, very few nights spent in it. The last 3 years it wasn’t used at all.
  • Glenn
    July 31, 2014 at 12:15 pm
    Wow… not used in the last 3 years may present you with a few surprises… best coaches are used a lot… be sure to have everything checked out properly.
    I love the Vantare conversions… I hope you enjoy it !!
    Cheers,
    Diane
Page 2 of 2
