You have a Classic and it’s a 12v coach. The only Vanner equalizer you will have is for the chassis batteries.
So Rocky, have you setup your appointment to go to Liberty? It will be interesting to see what they find out about all your electrical issues.
Rocky,
Yes, you have a Classic or a 12 volt house. It will not have an equalizer. Your chassis is a 24 volt, but uses 12 volts for certain systems and components which is why it has an equalizer. The purpose of the equalizer is to maintain the correct relationship between the 12 and 24 volt circuits (within 1/2 volt). My house is 24 volts but like the chassis the house also has some 12 volt systems and devices so my house battery bank also uses an equalizer.
Mark is correct in poking you a little to see if you got the electrical issues resolved. Over the years we have seen a lot of owners experience grief and some not so small financial losses caused by buying new sets of batteries because some problems were ignored. The learning curve on our coaches is steep and potentially expensive. Try to stay ahead of the curve.
Mark,
I get My House Batteries replaced Tuesday and I think according to some of Jon’s past experiences ( Fingers Crossed ) that will take care of My Gen Battery Charging issue. The batteries in there now , Are all Distorted and look like they could have came over on the Mayflower. They will hardly run any small lights when the coach is turned off, Then not for very long before they go dead. The coach charging system shows charging them when it is running , And the inverters work fine until the coach is turned off. Then I had the High Voltage issue on one side that I now know is caused by the Refridgerator. Since I have left the Fridge turned off , All is good with that. I have a good shop that caters to Houseboat and Coach owners in the area to take care of that. Also – ” No Power ” to the Microwave, A custom Coach Manufacturer in Nashville checked that for Me and showed Me voltage over to the Unit. Diagnosed the Mother board is out. Wife is ordering a nice Convection replacement online. Ceiling lights are fixed and working fine , Master switch by door might need replaced soon. So the only electrical issue that is left is the Watchdog unit for the generator. I have a oil pressure switch and sending unit ordered for the Gen. Troy @ Liberty told Me that the Powertech was notorious for the pressure switch going out. And that would cause the WD to fail. So I will have it replaced soon , And eliminate that before I take it to Liberty.
It now takes 2 weeks to schedule an Appt with Liberty. I will get all of this done and evaluate the Coach and Make an Appt then. But things are looking up !!! Might just have a very small list by the time i get to Liberty ?
What a learning curve to purchase one of these Beautiful Rigs !
Thanks,
Rocky
Yes , What a learning Curve it is ! You have to Love them to do it !
See My Reply to Mark,
Thanks,
Rocky
Rocky,
There are many others reading your experiences and learning from them. Apart from tires over which you have a lot of control during their life span, batteries are high on the list of expensive things that can make coach ownership very enjoyable or miserable. If you note one of the first things I mentioned was to separate the batteries and check them. One bad battery in the house or the chassis can create problems that make no sense.
When you replace them make sure all the batteries are the same date, make sure the inverters are set up for the specific type of batteries and that you take the time to insure all connections are clean and tight, including those at the master switches and circuit breakers and grounds. As long as the batteries are out you can do that easily with no concern about sparks or burns.
Just so everyone understands the importance I will repeat……..make sure the inverters are set up for the specific type of batteries you install. And then monitor the voltages to insure they are limited to the charging voltages specified by the battery manufacturer. Otherwise you have another new set of batteries in your future.
It is too bad new owners fail to take the time required to a complete coach inspection before money changes hands, especially when the information required to do that inspection is available thanks to the internet.
I am placing the batteries that Troy recommended. There is no doubt that they need replaced after learning on here and from the Coach dealer in Nashville how everything works. If they had come close to working like they should , I was going to test / Clean everything per Yopur List. If Steps A,B do not pass , There is no reason to continue on to step C. I can now add the Webasto heat to My repair list , And I noticed that Prevost is running a special on that until around the end of November. ( Unless I just do not know how to operate it ? ) I can turn the rocker switch on the dash on, And the Green light comes on for a few , And then goes off. I have the Thermostats on switch to the on position with the temp turned up. I can hear a fan kick on under the drivers dash, And there is a fan that works in the Mid section from the Thermostat. But I cannot hear the system ignite , And cannot find any Exhaust coming from it.
BTW , I never got to talk to the previous Owner, Or I would have had a Million Questions. And had them give Me Mini Classes on all operation systems. I paid for the Coach before I ever seen it , Talk about a Scary thing !!! After purchasing it , And taking it to Prevost in Ft Worth. The Service Manager told Me that the Previous Owner was bringing in His OTHER Coach in a few days for service. It is a 2011 Prevost. He Has good taste in Tires, He had placed 8 New Michelin’s tires on My Coach within the last 5K Miles I would say. And left 3/4 of a tank of Fuel in it !!! I thought the gauge must have been tore up ??? Run it down to 1/2 and filled . Took 115 gallons. New Shocks also. So I was in the right place at the right time for once ! The Coach seems to be in Fair to good condition for the age , With the exception of the Refridgerator , Microwave and House Batteries ?
Having never even been in a Prevost until I stepped into this one. I really had no idea how to operate one. Remember that learning curve We were talking about ? You have no Idea !!! We looked at Class A Rv’s for Months about 3-4 tears ago. And ended up Buying a Cabin that was centrally located to Our Work instead. We came really close to Buying a new Damon Tuscanny W/4 Slides back then , I am now glad that We waited and ended up with the Prevost ! I have found this Forum to be PRICELESS ! With all the information and Help from the Other Owners, It has Helped Me a LOT ! Special thanks to Jon for all His Replies with His past Liberty knowledge !!!
I have admired these Majestic Beasts on the Hwy My entire Adult Life while Traveling ,Which I done for 25 years without ever being able to unpack a suitcase. It has always been My dream to Own one , And Now I do. So Time to get the Bugs worked out , Learn How to Maintain and Operate it , And Enjoy it !!! And go See Amurica ! The Red Woods , Yellowstone , Colorado , Montana ,Rushmore , Etc. And Wade and Fly Fish the best Rivers this Country has to Offer , And Ride the best Roads I can find on My HD with My lovely Wife on day trips away from The Prevost . And Play Golf on some of the fine courses this Country has to offer! And of course enjoy all the food from the different regions ! No concrete plans , Take 30- 45 days at a time and pick a general direction maybe. Stop when We want to , Etc. Will that ever happen ? Not Sure , But it is on My Bucket List !
Rocky Lane
Hey Rocky, a banjo player walks into a Walmart and realizes that he’s
left his banjo in the backseat of the car and forgot to lock it! So he runs
back out to the car as fast as he can, but it was too late …there were already three
more banjo’s and accordion!Have fun with your “new to you” coach, the guys on this form are very good at advise and sometimes they are right too!! J/K!
Fred
We’ve never promised correct answers to questions. However our advice is worth every penny you pay for it.
Hey Fred,
I have a place on the Cumberland River , I thought I would learn the Banjo so I could sit on the River bank and wait for City Slickers to come paddling By !
I Love My New to Me Liberty ! And What a great forum This is !!!
Thanks,
Rocky
I sure have been getting My Money’s Worth !
Thanks Again for all Your Advise !!!
Rocky
I changed out the House batteries with Deka Gel that Troy from Liberty recommended. Which I found a local House boat repair place that gave Me a great deal on them. Several hundred cheaper than what it was going to cost to have some delivered. And things immeadately started looking better ! The old batteries were enlarged / Swollen up and were definately in need of replacement. My charging issues cleared right up. But My fluctuating AC did not. I noticed that the Male 50A plug on the end of the power cord had one blade that was getting hot. Had turned black around the base where it meets the plastic. I chopped that off and replaced with a good plug. And all AC issues have been resolved ! Thank Goodness !!! I suspect that the old plug had been jammed into the gound enough in the past from some lazy operators turning the cord reel on and driving it into the ground directly thru the floor below the electric reel. I now bump it down until I can get enough slack to bend it out from under the coach before leaving the pay out switch on ! Now , I have ceiling House lights that do not work that I have run down to a Ford Style 4 post Relay. The RV parts guy said there were 2 types, One for starting , And one for Charging. And the one that runs My House lights would be the charging style. I have 2 of them ordered and should have them in My hands tomorrow. There is however a small resistor between the 2 middle posts that I need to ID and get. It is solid Black with one Silver band on it. Can anyone tell Me the value of it ? My memory fails Me from My electronics class in HS 35+ years ago.
My repair list is getting Shorter ! Then it’s Maintenance , Shine , Enjoy !!! And polish My COPPER !!! LOL !
Thanks,
Rocky
Rocky,
I think you are describing the standard relays that are used throughout the automotive industry. The component you describe sure sounds like a diode. The diode’s purpose is to suppress voltage spikes. FWIW, some relays use resistors to achieve the same goal. Here’s a great document on relays and the diode you described: http://www.autoshop101.com/forms/hweb2.pdf
Right here on this very site, free to all who want to take the time to read it is a great article on relays and it talks about theuse of diodes or resistors for suppression.
http://prevostcommunity.com/PDF/Ralays.pdf
Another service we provide.
Thanks Gil ,
Is it a Must to have one of those ?
Thanks,
Rocky
