  • General consensus
    Posted by Chuck & Katrina on July 10, 2022 at 10:28 am
    The oil seal on my drive pulley for the serpentine belt is starting to leak (I wiped up the excess oil be for I took the picture).
    Can I just purchase a replacement seal or will I need to buy the entire Assembly and replace it?
    Chuck
    Leesburg, FL
    Bill replied 4 years, 4 months ago 5 Members · 5 Replies
    July 10, 2022 at 10:54 am
    The potential for oil to weep or ooze from our coaches is everywhere. It can come from power steering fluid, differential grease, engine oil, A/C compressor oil, etc.
    Fluid leakage is second on the chart of what annoys us only second to air leaks.
    Every leak is repairable, but the question I ask myself is what is the cost or hours required to stop the leak, and is it worth it. Common leaks such as the seal behind the clutch on the A/C compressor, or the shaft seal on the 50DN, etc. are almost as common as air leaks, but until they get more serious I spray the area clean with brake cleaner at every service and quit worrying. It might be my age or my thinking $30 worth of spray cleaner every 5000 miles seems far more economical than 3 or 4 hours of my labor and $150 worth of parts.
    July 11, 2022 at 9:01 pm
    LOL Jon:
    I think I am turning to your page or just cleaning the oil leak instead of parts and labor.
    On a different note:
    I spend hours finding and stopping air leaks only to have them start again on my next trip. Interestingly enough, my last trip of 3,500 miles my leaks seamed to slow themselves down all by themselves.
    Just when you think you have things figured out…
    Chuck
  • Michael
    July 11, 2022 at 10:14 pm
    Come on Chuck, of all the work to do on a bus, you are going to avoid changing that seal? In the realm of Bus work, that is pretty high on the easy list.
  • Unknown Member
    July 12, 2022 at 8:42 am
    Mike:
    The air leaks seam to be fixing themselves, maybe the seal will too LOL.
    On a serious note: can just the seal be purchased and replaced or in today’s world of throw it away and replace it, will I need to replace the hole pulley?
    Chuck
    July 12, 2022 at 1:52 pm
    Air leaks can come and go depending on outside temps. Colder temps bring more leaks.
