  • Gearbox Oil Change – Overfill question
    Posted by Michael on April 11, 2020 at 2:56 pm
    I have a quick question to those that change your own gearbox oil. I decided to do it myself this time on my 96 XL with DD Series 60. It is the Superior gearbox referenced here (https://www.prevostcommunity.com/forum/threaddetails.asp?Category=General%20Discussions&ThreadID=781) from a post years ago. I have the two hex ports (drain and fill) but I could not get either of them out, so I decided to do the suction from the breather hole method. Now to my question.
    When refilling, without the fill hole, I am estimating how much with a rod inserted. Right now, after filling, I am about 3/4 inch over my estimate of the correct amount (recognizing that it is hard to tell exactly). Is having too much oil a big enough problem that I should lower it some? I know too much could cause some over heating, but not sure how sensitive it is, particularly since I am not able to use the true fill hole method for accuracy.
    PS – Prevost service did the last change and I am not sure if they actually used the plugs, but I doubt it given that they do not look like they have been removed in a long time. I suspect they did something like I did.
    Appreciate any advice or experience you can share.
    Thanks!
    Mike Harper
    2004 Marathon XLII
    Michael replied 6 years, 6 months ago 4 Members · 4 Replies
    April 11, 2020 at 8:50 pm
    Here’s the service manual link LINK
    On page 3 they state: “In general, the oil level should be approximately half the depth of the gear drive (to the parting line) for horizontal mounting”.
  • Billy
    April 12, 2020 at 11:01 pm
    Don, Thanks for the info! I feel like I will take a little out tomorrow but otherwise feel like it is good to go.
  • Michael
    April 12, 2020 at 11:05 pm
    Mike Harper
    2004 Marathon XLII
  • darrell
    April 16, 2020 at 12:41 pm
    I have a 1998 Prevost with a radiator fan Superior Gear Box. I drained the 90wt oil and replaced with Mobil 634 140wt. Still noisy on cold start up. Quiets down some after warm up. Is this normal or should I look for a new Gear Box? Darrell
