  • Galley heater
    Posted by Thomas on September 26, 2019 at 6:32 am
    We are in Colorado and its not cold yet by any means but it is cool in the mornings, when we purchased the coach it was 115 deg so making sure the heaters worked kinda fell through the cracks… more concerned with the AC’s at the time (not all work that will be for a different thread) anyways we found out the salon and the bedroom heaters work fine (these are the ones on the floor with the knob you turn to adjust) but when you push the galley button on the panel it turns green and then starts flashing green/red and the heater does not kick on… any help to a starting point on where to begin would be greatly appreciated Thanks again
    Dan replied 7 years, 2 months ago 8 Members · 9 Replies
  • 9 Replies
    September 26, 2019 at 3:30 pm
    Our 99 Liberty had one Cadet toe kick heater. If that’s what you have they can still be obtained from Cadet. There was a recall on our particular model, but we were outside the free replacement window.
    You might try pulling your heaters out and trouble shooting them. They are usually pretty simple devices. There might over temp protection that needs to be reset. Just guessing.
  • terry
    September 26, 2019 at 9:21 pm
    On our coach, I believe the 110 Heat button in our bedroom panel must be
    selected and you have to double tap the heat button on the galley SMX pad.
    This is from our SMX manual:
    Auxiliary Heat
    (Factory set: disabled)
    Normally, the aux heat function is disabled, so that the
    compressor runs in reverse cycle heating mode without aux
    heat. When aux heat is enabled (see below), press the HEAT key
    once to run Reverse-Cycle heating only. Press the HEAT key
    twice quickly to run aux heat.
    To enable or disable aux heat:
    • Enter the programming mode:
    Press OFF.
    Press SET.
    • Press HEAT and SET simultaneously.
    • Use the UP or DOWN key to toggle the aux heat on or off. When
    aux heat is enabled the letters AH will be displayed . When aux
    heat is disabled, the Null sign (–) will appear.
    • Press OFF to exit the programming mode.
  • Dorel
    September 27, 2019 at 8:12 am
    Featherlite, Marathon and Liberty have different systems.
    This question needs answered by a Featherlite owner.
    September 28, 2019 at 8:18 pm
    I pulled the heater out and cleaned it re-installed it (it looked new the reset button was not tripped) and nothing the thing I don’t understand is why the panel button starts flashing green/red… any ideas?
  • Towson
    September 28, 2019 at 9:25 pm
    Just wondering, is Power Management Switch on?
    Or it might be a baseboard heater breaker in the basement panel that needs to be reset ??
    Gil
  • Jeff
    September 29, 2019 at 7:48 am
    Power Management switch is off I will check the basement panel when I get back to the coach (am away for a few days) thanks !
    September 29, 2019 at 12:44 pm
    I sent an email with my phone number. I have a 2001 H Vantare and may be able to help. Would require a long winded answer, so phone would be best.
    Fred
  • Dorel
    September 29, 2019 at 12:45 pm
    Oops, double post.
  • Dan
    September 29, 2019 at 7:14 pm
    did not receive the email try again… thanks
