G4 – LED
Posted by Archived on September 18, 2018 at 9:23 amThis question is for Marathon owners only because of Techlink.
What LED bulbs did you go with for the ceiling lights that are dimmable?
I used these on my 02 and they worked fine.
High Bright G4 24 SMD Cabinet Marine Boat Reading LED Light Bulb Warm White
Archived replied 8 years ago 24 Members · 41 Replies -
I will go by bus today or tomorrow and check. Ours work good and have not had any issues.
Attached is picture and description of LED lights we are using.
Using the same as JD post above.
Expensive, recommended by Marathon, dimmable. compatable with techlink and S-2 or S-3 boxes….. no issues.
part number……GG4-PWM-WW36
Tom I also use the same lights as Jd showed, but I didn’t pay Marathon prices, I ordered them off amazon, I think for about $14 each. Expensive but gets rid of a bunch of heat.
One thing that might make a difference in Marathon buses.
A change was made at Prevost introducing the MultiPlex electric system appox late 2006.
Most all relays are gone replaced by ECM’s mounted bank style in drivers bay.
I have it my coach # 1075…..Buddy has it in coach # 1080. I mentioned the S-2 and S-3 control boxes now doing most switching and compatable system with these expensive G-4 LED bulbs.
I’am sure their are cheaper LED’s around.
Tom, I have this different bus now where the ceiling lights are dimmable. Does that mean I have “techlink”? What is “techlink”?
Ahh good, the word “tech” gives me attitude for which I know no prescription.
I replaced all lights to LED in the 1997 Marathon. This is an older system and had some trouble in the beginning.
Finally figured out that the load was too low and made the lights flicker. Resolved the issue by leaving one halogen per group of lights. All works great now!
Bulbs I bought are $ 1.50 each from superbrightled.com
Note, when I did the factory tour I noticed superbrightled.som stickers on some of the workers tool boxes. Wondering if Marathon uses their products…
Link below is hot direct to …
Have heard that one regular bulb will stop the LED bulbs in string from
flickering too. The other factor is usually the dimmer switch itself. You
need to upgrade the dimmer to LED compatible dimmer.
Hey Mark, these bad boys are up to 210 each on Amazon, GG4-PWM-WW36.
They must have discovered the word Prevost.
$16.25 each GG4-PWM-WW36
I ordered one and will do the entire coach after testing.
I went to that site also Jimmy, shows they only have 3 in stock.
