  • Fuel tank capacity?
    Posted by Bill on August 22, 2022 at 7:29 pm
    Is it possible that my 40′ 1998 CC has a fuel tank that holds less than 200 gallons? I thought the standard tank was 205/208 gallons, the same as what I had in my 1988. However, the fuel gauge shows 1/2 and I take less than 100 gallons. Today I was down to 1/4 tank and only took 131 gallons. I know the gauges aren’t perfect but the gauge reads full about the same time the auto fill cuts out so it seems the top end is right but I am concerned about running out of fuel if I try to push too far. The low fuel light will come on as we drop below 1/4 tank but it “seems” like I should have less than 50 gallons at that point when in reality I still have 75+ available. Just curious if there were smaller tanks installed that anyone is aware of. If I call Prevost, would they be able to confirm what size tank was installed in this particular coach?
    Isaiah replied 3 years, 8 months ago 18 Members · 26 Replies
  • 26 Replies
  • Ken
    August 22, 2022 at 8:08 pm
    I feel your pain. I am paranoid about running out of fuel.
    August 22, 2022 at 8:28 pm
    Bill, mine is a little older than yours, but I have a 160 Gallon fuel tank.
    August 22, 2022 at 11:22 pm
    My 1996 40 is also 160 gal.
    August 22, 2022 at 11:39 pm
    Bill
    you can call prevost elgin parts and ask for your shell build sheet per Vin number. That will tell you fuel tank size
    August 23, 2022 at 12:21 am
    Our 96 Liberty XL40′ has 250 gals.
    Standard tank is 160 gal. Optional was a second interconnected 90 gal tank.
    August 23, 2022 at 9:24 am
    Our 1988 CC had a 205 (or 208) so I know there are more options than 160 and 250. 160 would make some sense based on the fuel gauge actions. I will check with Prevost, thanks.
    August 23, 2022 at 10:04 am
    Mine is a 97 40 ft also and like Don said 160 plus aux tank is 90, If you have aux tank, In front bay mounted up against back wall. My last trip to Oregon my fuel gauge was at a bit under 1/2 tank took 100 gallons
  • Alex
    August 23, 2022 at 5:39 pm
    Like Bill said, ours hits E when we’ve burned 160 gals. I rely on the Detroit Pro Driver that I know is accurate. But, it doesn’t add the genny fuel usage. I add 1 gal/hr for gen run time.
    Our biggest fillup so far has been 210 gals, and the gen would still run.
  • Jim
    August 23, 2022 at 6:16 pm
    Bill-
    ’96 xl40 160gal. Think this is pretty standard unless like Don said you have the optional 90gal reserve.
    If your cost at the pump isn’t high enough, come to CA where 160gal will set you back over $1100.
    August 23, 2022 at 6:59 pm
    That’s just where I am headed. We are in Las Vegas for 2 nights tonight and then onto Santa Ana followed by Atascadero. Hope to get some time in Ventura along the Pacific Coast after that. Company pays for fuel so I should be OK!
  • Deleted User
    Deleted User
    August 24, 2022 at 1:42 am
    Bill-
    Sounds like a good trip. It will be warm in Atascadero mid to upper 80’s, but that may feel cool after Las Vegas. Ventura will be cooler. Ventura is great!
  • Rudy
    August 24, 2022 at 10:53 am
    Yep, 107 in Vegas yesterday. Only 101 today! The only good thing about being in Minot, ND for most of the summer was the great weather. Santa Ana puts us close to Huntington Beach which we love and staying along PCH 1 in Ventura is super special. Bonus is my Sister lives nearby. Should be a great trip and easy work.
    August 24, 2022 at 9:43 pm
    Were going to Rincon Beach in Ventura in 2 weeks, Great sunsets
  • Mike, 92 Country Coach
    August 27, 2022 at 1:50 pm
    Yep, that’s that place, just could not think of the name. They were supposed to be going to reservations required setup. Do you know if that ever happened?
    August 27, 2022 at 5:07 pm
    Rincon does require reservations.
