  • fuel lines replacement
    Posted by Bob on October 6, 2013 at 2:01 pm
    Again fwiw info. Behind the Ac condensor there is a access panel you can get to the fittings on the tank. Easy to loosen them. You can lay on your back last bay and take the two screws that hold lines to ceiling out and from there if you are determined to remove old lines you might as well pull you hair out first! because in a older coach most of the fastners will be frozen and impossible to get to. They run inside curb side frame rail on the 98 XLE. The good thing is the new hoses with fittings easily fit thru bulk head openings and the bushings are split and snap in after hose is thru. I just installed new brackets and cut out what was left of old hose—actualy just pulled it out.. You can access fuel sender and tap fuel tank for gen set there thru the access panel in the AC condensor compartment also. Plenty of room. Dirty area. Bob
    Bob replied 13 years ago 1 Member · 0 Replies
