  • Fuel consumption
    Posted by Rod on September 30, 2012 at 8:03 pm
    Can anyone tell me the difference in fuel consumption between the 17.5 kw and a 20 kw generator?
    And what would be the advantage of one over the other if any?
    Thanks!
    Rod
    Larry & Diane replied 14 years ago 3 Members · 2 Replies
    October 1, 2012 at 8:10 am
    Rod,
    The fuel consumption comparison would be negligible. The choice of
    17.5 vs 20 is determined by the converter based on AC loads, such
    as 4 A/C’s instead of 3 and other electrical components.
    October 1, 2012 at 8:33 am
    Other than a slight difference in internal friction on the two engines my guess is the fuel you use is directly related to the power you consume. I have a 20 KW and one of the best things for a generator is to run it hard and often. Because of that a 17KW may actually be better because the most I have ever been able to load my generator is about 100 amps total and that was with all ACs, water heater, and using the grille.
    As a practical matter fuel consumed by our generators is such a small part of the cost of owning a coach it is irrelevant. I ran mine once for about 170 hours and the fuel used was about 71 gallons.
