front elect compartment post ##
Posted by Bob on October 20, 2013 at 4:10 pmMy chart is gone off door and I need source for post #’s looking for turn signals and clearance light #’s. For now —I can do bell test but if some one has chart it would help. Going to get new one or at least list. for some reason I’m having trouble finding listing by post numbers. Is there something this old mind is overlooking?? Circuits 21 and 23 serries… I am searching the prevost wiring diagram on prevost car but must be missing something. Bob
gary replied 13 years ago 5 Members · 9 Replies -
I don’t if this what you need or not but all the 21 number thru 21P are for the left side turning signals and cornering lights 21 B is the hazard
23 is for the right hand side 23 thru 23 P same as the left side that is on a 96 model I don’t think any wiring diagrams changed in 2 years
good luck
I am sorry Monday I will break it down for you on what wire goes to what light ok all 21 are for the left side and all 23 are for the right side, damn I wish I could make the edit function work on this board
good luck
Wire ## are 21-23 is that also post #’s Would be to good to be true—will check in the morning.. Was thinking of running new wires to rear instead of splicing harness where it burned into. I’m good on clearance lights etc until last set and tail-stop and rear clearance lights. Was thinking of just running a new set to pick up them insread of tapping damaged harness. I need to get that elect schematic from Prevost so I know breakers post etc. I have like a site local for breaker but no idea where that site is(map of location)–example address but no street name.. The glue is still on the door but elect diagram is gone.I do have the elec section from prevost but can’t find which Post the wires hook to in front elect compartment. .Thanks Bob
Bob have you tried to get a new label or drawing from Prevost? Have you tried the publications page or tried to get the diagram part number from Prevost parts?
publications page;; never thought about that— Will get on rite now! Other wise have misc parts list I need to order will see what parts guy has. Need diagram for future referance! Bob
Allen,
If you don’t see the Edit and Reply button on the bottom of the page, you are not logged in and visiting as a “guest.”
I do see the edit at the bottom of the page next to the reply when I click on edit it tells me the post does not belong to me in certain words I have never been able to edit a post here and this Dell with windows 8 is a pain one never knows what it is going to do
good luck
Ever get a case of the blanks—- forgets?? In the symbol for the front junction box there is a number. That number is the stud/post the connection-feed is on. I need a jog once in awhile. All is good in busland. Bunch of bulbs need replacing only about 1/3rd came on=just might all end up LED next year. Still going to order the schematic for the compartment door. Thanks for helping me reboot. Bob
