  • Front brake Maintance
    Posted by Art on May 8, 2023 at 10:01 am
    After summer I want to replace the front disk brake rotors and new Pin bushing in Meritor calipers and wheel oil seals. The rotors can be replaced and reuse hubs?? Never did this before, What kind of job is it, I’ve replaced caliper pins but not bushings, press old bushing out or drive them out?? My friend helped me years ago with the Foretravel front wheel seal that was leaking, He said that there is a couple of different types of wheel seals?? Anyone done this job before?? Rotor- bushing Part #’s
    Archived replied 3 years, 6 months ago 5 Members · 7 Replies
  • 7 Replies
    May 9, 2023 at 10:13 am
    Is Prevost the best place to buy rotors? or Meritor?
  • Tom
    May 9, 2023 at 3:03 pm
    Art, where ever you get the parts add Meritor helper springs for the slide pins.
  • Chad
    May 10, 2023 at 9:59 am
    Hey Rudy It already has them.
    1984 96" with 8V92TA
    (remodeled Liberty Coach)
    Greenwood, MO
    May 11, 2023 at 7:49 pm
    Nobody has replaced rotors before and nobody knows about Meritor 1560 ADB air disk brakes???
    May 11, 2023 at 8:39 pm
    Frt. & Tag axle wet hub seal part# = SKF # 35066 = Prevost # 610870
    Steer axle rotor pt # Meritor 3218-Y-1065
    Caliper minor rebuild kit = Meritor K15001
    Old spec = slide pin kit with o-ring = KIT15013 or KIT15003 kit, pin dia .990” = Prevost# 611100
    New spec = slide pin kit wo o-ring = KIT15016, pin dia .988” = Prevost# 611169
    Torque plate bushing kit Meritor 1225M1001 (per axle)
    Caliper bushing kit Kit15010 (per caliper)
    May 11, 2023 at 10:56 pm
    Robert Hitt – Prevost Customer Support Manager sent me the following info to pass along:
    Recommended Pin Kit
    Over the years we have also learned not to use the pins with O-rings, this was a recommendation for bus application made by Meritor over 20 years ago.
    In this application the O-rings tend to promote dirt to accumulate and cause the caliper not to recenter because the spring can’t overcome the drag on the pin.
    We would also see the O-ring when overheated get sticky and add to the problem.
    The pins without the O-ring are actually slightly smaller allowing the caliper to slide a bit easier. Inspect the pin bushings, they tend to wear on the leading edge only causing an egg shape.
    If you hear a slight clunk when doing a light brake application this could be bushing or pin ware. Once the bushing is gone you will damage the bore of the caliper.
    If your ordering Parts from Prevost we should only sell you the one without the O-rings
    Old Kit 611100 Meritor # 15003 Pin Diameter .990
    New Kit 611169 Meritor # 15016 Pin Diameter .988 (Recommended) (identified by NO O-ring)
    May 12, 2023 at 8:58 am
    Thanks Don I already replaced the pins with out O rings and already rebuilt Meritor calipers with minor kit all 4,New pads, Just front rotors have small cracks,not bad but I would like to replace them, The Meritor helper springs were already there. Never replaced oil seal so it would be a good time to do that and new gear oil. Rotors replacement on steer Axel only spray some lube on all those nuts and remove?? Bushing’s were just a little loose
