Foot rest motor bad
Posted by Tony on February 19, 2021 at 3:56 pmI have H3 2002 Vantare and leg lift has quite wiring and looks the the Mfg Track Corp is out of business. Has any one found a place to get the drive motors for the power buddy seat! Seat model is 53704. Any help is appreciated It
Archived replied 5 years, 8 months ago 5 Members · 7 Replies -
Hi Tony,
i somehow missed your post originally. When I did mine I found the motors and gear boxes were like tinker toys – mix and match. A poster here had a motor and drive that looked right in the pics but was a mirror image of mine. In my case the worm drive was stripped. I was able to disassemble mine and use pieces from his to fix mine. Easy to do once you unbolt the seat from the floor and have the chair on its back.
Pushed to many buttons, am I still allowed to be on this site, even when I don’t know what I’m doing most of the time ??
Leesburg, FL -
Most of the time it’s the gears that go bad. Flex Steel made the seats, gears were redesigned but they will still make one special order for you. You can remove the motor/ transmission with the seat in (real pain, I did it twI did it twice) so you can bench test the motor w/o the gears attached
Hi Dick,
We talked about this at the time. The parts were correct but the brackets were mirror images of mine. I took the parts out of what you sent and put them into my existing bracket to make it all work properly. Thanks again for your help and generosity in sharing your stash of parts.
‘Jerry
