  • Fire Alarm goes off intermittently Please help
    Posted by Richard on July 10, 2016 at 10:42 am
    I’m parked in a RV park in Michigan and the coach fire alarm goes off intermittently. I can cancel by pressing the coach’s key FOB. I have no idea what is causing it to go off. How can you determine what is setting it off. I’m a new coach owner and this is a 2001 Featherlight Vantare double slide H3-45. Any help would be appreciated.Does anyone know of a Prevost repair facility near Grand Rapids Michigan?
    Dorel replied 10 years, 4 months ago 7 Members · 8 Replies
  • 8 Replies
  • Dan
    July 10, 2016 at 1:54 pm
    Do you mean smoke detector? I know if the batteries are low they will beep intermittently. Have you replaced the batteries? Hope this helps
    July 10, 2016 at 2:51 pm
    no it’s definitely the engine fire alarm…I disconnected 3 plugs in the back drivers side switch relay compartment as instructed by Prevost Support. I had trouble with this alarm last fall and I guess the way Prevost New Jersey tried to fix it with wire ties didn’t last very long yet they charged me $350 for the repair.
    Its pretty bad when Prevost doesn’t repair things correctly….Anybody know a good place?
    July 10, 2016 at 3:31 pm
    The fire alarm just went off again. So I unplugged the large plug on the left….does anyone know if the 3 on the right should be unplugged or plugged to stop the alarm?
    July 10, 2016 at 4:05 pm
    Panterra is in Holland, MI, maybe they could offer a suggestion tomorrow.
    I would think ther would be a way to kill the power to the alarm. Prevost guarantee’s their work for a year, so hold their feet to the fire.
  • Kevin
    July 10, 2016 at 4:14 pm
    Thank you I will try them tommorrow….
    I found out that the unit is an Megatech Electro Inc (Quebec, CA) Overheat sensor device that monitors 3 locations on the coach for over heating. Megatech Electro Inc. was bought by SMTnet so I don’t know if they are still in business.
    July 10, 2016 at 7:45 pm
    I washed the engine compartment on one of my Liberty’s & wet the sensor and the alarm came on ,I tripped the breaker in the driver side electrical box to turn it off, after a day it dryed out and it was ok.
  • Shelby & Barbara
    July 11, 2016 at 1:33 pm
    Could you explain specificallly which bay and electrical box and switch you tripped?
    Thanks in advance!
  • Dorel
    July 11, 2016 at 2:52 pm
    Drivers side outside of the drivers window electrical panel, I dont remember the breaker number they are labled
