  • Featherlite Electrical issue
    Posted by Archived on May 23, 2017 at 7:04 am
    I need some help to understand what is happening in my electrical system:
    Remember this is a 2001 Vantare
    Plugged into shore power 50amps
    1. Inverter #1 circuits went off, 2 ACs, washer & dryer, about 33 amps load
    2. Reset everything, reduced load to 15 amps and watched
    3. Input voltage dropped to 1.7 volts (!!!) for about 3 or 4 secords then returned to 118
    4. Removed shore power, started generator, same symptoms
    5. During this time, inverter #2 was functioning normal
    6. Power cycled inverter #1
    7. Same tests, same results
    Now running on shore power, Inverter #1 bypassed, #2 normal
    Dick replied 9 years, 5 months ago 2 Members · 1 Reply
  • 1 Reply
    May 23, 2017 at 12:39 pm
    Roy,
    Call the guys at Inverter Service, tell them you’re a PC guy and they will help you out.
