  • Faulty Coolant Filter
    Posted by Archived on December 18, 2014 at 6:44 am
    I found my coach was leaking coolant recently. After having lunch with a member who recently had his engine water pump replaced due to leakage so I was prepared for the worst.
    As it turned out finding the leak wasn’t so easy, and no matter where I looked it seemed to be the source of the leak, including around the water pump. It was by accident while trying to dry everything out so I could have a better chance of finding the origin that I noticed the red color of the coolant around the seam of the coolant conditioning filter. On my coach it is located on the engine above the water pump in an area where there are a lot of coolant lines and as it dripped down from the cartridge the coolant would spatter and end up all over in the area of the water pump.
    Prevost is sending a new cartridge. So the reason for the post is if you think you have a water pump leak, make sure you do in fact have a leak at the pump and that it is not somewhere else.
    I don’t know about other conversions but my Liberty has a lot of coolant lines that have to be removed before being able to get at the water pump. However in some cases if the water pump is leaking it can be repaired without removal or replacement. Detroit Diesel has a repair kit part number 23538693 that can be used to repair the common leaks and it does not require the removal of the water pump
    Archived replied 11 years, 11 months ago 2 Members · 3 Replies
    December 18, 2014 at 10:38 am
    Why does the coolant filter need to come from Prevost ?
    December 18, 2014 at 11:31 am
    I would assume it’s also a blank, thinking you’re on extended.
    I had one leak also and it was a Wix.
    December 18, 2014 at 12:46 pm
    It does not have to come from Prevost, but for the saek of expediency I was getting a lot of stuff for the coach at the time (shocks, air dryer cartridge, belts, tie rod, etc.) so it was easy to add that to the list. I usually get it at Truck Pro (Baldwin or Donaldson) and sometimes Detroit.
