  • Fan motor kaput
    Posted by Chip & Pam on July 15, 2015 at 10:02 pm
    hello PC’rs
    i need some help. I have a Dometic penguin heat pump that the fan motor has gone south. The AO Smith part number is 3106070.000 & model is F42C02A61. The problem I have is that the motor is no longer in production. Do any of you have a cross reference model that will mate up? I see a ORV4540 model online, but I’m not sure if it is a direct replacement.
    Im down to 2 units and need to get number 3 back online ASAP. It’s hot, muggy and it is July in the swamp we call DC.I need a part supplier that can reference me the replacement and has it in stock.
    Archived replied 8 years, 1 month ago 5 Members · 6 Replies
    July 16, 2015 at 11:33 am
    If you have an electric motor repair shop nearby they might
    be able to repair the one you have.
    Ken
    July 16, 2015 at 1:02 pm
    Maybe W. W. Granger can help.
    If you have one localy take the motor to them.
    If you can get the specs off the motor that might help, not neccessarlly the Dometic part numbers but the actual label off the motor if there is one.
    If none of that works, try any RV dealer with a shop, I bet they have a pile of them out back you could get a motor off of. New would be nice but if you are in a bind it would work.
  • Chris
    July 16, 2015 at 8:22 pm
    ken & Buddy
    thanks for the replies. I have been in contact with Excalibur in Sanford. They have a direct line to Dometic. Doug and his folks are getting me the replacement motor and capacitors.
    If all works out ill post the part numbers on this thread so anyone else needing the parts can have a reference.
    chip
    July 16, 2015 at 10:45 pm
    Nick Badame refrigeration Cape May NJ. Works on coaches also. A friend and 2nd generation busnut. Bob
    October 12, 2018 at 1:09 pm
    Chip did you ever learn if there’s a direct replacement for the AO Smith Motor F42C02A61 ? Mine is caput and I’m sorting out what to do here for a replacement.
    I actually have 2 of my 3 AC’s down and need capacitors I think for the other one.
    October 12, 2018 at 9:32 pm
    Wow, that thread is 3 years old, Chip sold his bus Jeff and probably not on the site anymore.
