  • Fan clutch testing
    Posted by Brock on June 20, 2020 at 1:35 pm
    Hey I am changing radiator, and CAC. Figured I would test the radiator fan clutch while everything is easy to get at. So I did some testing with engine off and key on. When I pull in the high speed coil it locks up solid. All good. When I pull in the low speed coil it pulls in and has some drag but not much. With it in low speed belts tight I can still spin the fan. To the point if I wasn’t testing it I could not tell the difference between low and off.
    My question is this. How much friction is normal in low speed.
    Art replied 6 years, 5 months ago 2 Members · 1 Reply
  • 1 Reply
    June 20, 2020 at 6:37 pm
    Not much friction is normal for low speed and solid is normal for high speed.
    Test to do at the 3 prong(A, B, & C) fan clutch connector:
    A is for low speed, gets 24+volts on the bus side of the conector, and 30-36 ohms between A to C on the fan side of the connector;
    B is for high speed, gets 24+ volts on the bus side of the connector, and 14-17 ohms between B to C on the fan side of the connector;
    C is ground
