Fan Clutch High Speed Relay Test
I had my fan and clutch assembly out to take care of some surface rust on the steel braces and brackets at the radiator. This gave me a perfect opportunity to check the smoothness of the fan clutch as well as a look at the turbo to make sure the shaft was free and smooth turning without a lot of play.
After getting it all back together, decided to break off the #85 tab on the R78 relay to get the fan to run high on idle to be sure my fan alignment in the shroud was good. In a earlier post at “Ask Prevost” the Prevost Tech made this comment:
When you have the tab off the relay and you simply turn on the ignition switch(don’t start the engine!), go to the rear and grab the fan blade. It should not turn as it should be locked in electrically. If it still turns but with resistance then I would look to the fan clutch as the problem.
Mine does not lock up, but you can feel a resistance when trying to spin the fan. Once the engine was running, the fan was spinning on high as intended. After reading the above, this suggests that my clutch fan may not be working properly because it’s suppose to lock the fan. I also tried it on R79 (speed 2) with the same results.
The bus has never run hot and I know the high speed works as I can see it on the gauge when it cycles and now wondering if the Prevost information above may be incorrect.
Anyone else tried this lock up test with the ignition on and relay modified, or willing to give it a try? Sure don’t want to buy a clutch if not needed.
