Fan Belt
Posted by David on August 9, 2022 at 8:55 pmI am looking for the belt number/ part number for the Fan on a series 60 it’s about 2 inches wide .. thanks
john replied 4 years, 2 months ago 8 Members · 12 Replies -
Call Prevost parts with you VIN. They are very helpful.
Chuck
Dave, I like these guys for all my Belts.
Most likely 3/A74 like this one on my 98.
https://www.amazon.com/gp/product/B06WWG99QP/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
You should have a pulley that has 3 grooves for belts to ride in and this has all 3 molded into 1 belt.
This one came with my bus as a spare. Miter box to fan. 10PK1297
1 – 3/8″ x 51 – 1/2″ OC
35mm x 1309mm OC
Am I misunderstanding what belt you need? The belt (usually 3 of them or a 3-in-1 belt) that runs from the engine take-off to the radiator fan pulley is not a flat serpentine style belt on any series 60 I have seen.
I tried the single belt on a couple of my buses and took them off, the shaking and vibration at idle was too much for me.
I’ve seen posts on other Prevost social media posts that weren’t as kind about 3 in 1 belts that Tom was. One or more complained about the 3 in 1 coming off too often.
I have used the 3 in 1 belt on both my ’88 (over 300,000 miles) and on my current 98 without issue. I took off the 3 individual belts as soon as I bought this coach and like it very much. I do replace the belt every 12-18 months and keep the one I replaced as an emergency spare……every though 1 has never been necessary.
It also runs smooth as silk.
I have a 3 Wide belt driving my Radiator fan, and a 2 wide Belt driving my chassis alternator. No issues for me.
Belts for our 96 Liberty XL40 12v Classic w/60 series & OTR:
90 degree gearbox to fan clutch (serpentine)=Dayco# 5100510(10 rib, 51”)
For the 24v alternator (serpentine)= Dayco# 5120720(12 rib, 72”)
Crank to 90 degree gearbox(v-belt) = cogged banded #AX74/03 from the V Belt Guys
or
3 matched Dayco# AX74(0.53”w by 76”L)
Crank to OTR 05G ac compressor(v-belt) = cogged banded #BX97/02 from the V Belt Guys
or
2 matched Dayco# BX97(0.67”w by 100”L)
90 degree gearbox to 12V house alternator(v-belt)=1 Dayco# BX31(0.67”w by 34”L)
I prefer the cogged banded belts vs the matched sets where applicable.
Your results may vary.
Leesburg, FL
