  • Exterior Cellular Antenna
    Posted by Chuck & Katrina on September 13, 2021 at 10:14 am
    I had an older Verizon Jetpack WiFi hotspot that I mounted in the back of the bus, tethered it to a route with the USB cord and connected a external 5Db antenna (magnetic trucker style antenna) to the Jetpacks external antenna port. This has worked well for me in most all situations.
    I have just upgraded to the newer Verizion Jetpack (8800L) with 2 external antenna ports. Not knowing if the current antenna I have would work or if I needed dual antennas because of the dual antenna ports on the new Jetpack, I called Alternative Wireless (AlternativeWireless.com). After explaining my past system and current upgrade, I waited to be sold the latest and greatest antenna system. The rep told me I had the correct system and didn’t need to upgrade anything for proper operation of my new Jetpack. It is refreshing to speak with a company representative willing to give you the correct information instead of a sales pitch and a up sale.
    Would recommend contacting Alternative Wireless for your wireless needs.
    Chuck
    Leesburg, FL
    Gary replied 5 years, 2 months ago 3 Members · 2 Replies
  • al
    September 13, 2021 at 11:41 am
    Thank you for the info. Certainly is not the norm in this day and age.
  • Gary
    September 13, 2021 at 12:17 pm
    I’m a big fan of Pepwave products. I’m currently running their Surf SOHO MK3 system. It supports MIFI modems tethered via it’s USB port. No loss in re-broadcasting a wifi signal. I’m running a mix of wireless and hard wired devices and having great luck. Highly recommended.
