  • Exit light switches
    Posted by Dean on August 26, 2013 at 7:49 pm
    My exit light switches by the entrance door will not shut off independently. If I shut the master lighty switch off then the exit lights go off. Anyone have an idea what might cause this?
    Jim/Chris replied 13 years, 2 months ago 3 Members · 4 Replies
    August 26, 2013 at 8:01 pm
    Sounds like a relay issue Dean, but I’m not familiar enough with Vantare.
    August 26, 2013 at 8:40 pm
    On our Marathon there is a switch so I can over-ride the master switch. I’am not on the bus and just a guess on the switch label is…. entry.
    So is there a seperate entry switch at some spot near the door.
    When we’re leaving for evening cocktails to watch the Lawrence Welk Show… at Jon’s and Di’s bus , I’ll leave the light on.
    August 26, 2013 at 10:36 pm
    Check the switch panel on either side of the bed. Our
    Vantare has a switch labeled “Exterior Lights”.
    Pressing this switch turns on the exterior lights (go
    figure) but doing so disables the rest of the individual switches throughout
    the coach.
    As I understand it, the thought process was to have a single
    switch to turn on all the outside lights in case of a disturbance rather to hit
    right side, left side, door light, etc. I am not sure why they set it up to disable the other switches but they did.
    Seems like a good idea but the down side is once and a while,
    when someone makes the bed in the morning, we hit the switch by mistake and the
    lights stay on all day.
    Hope this helps,
    Paul
    August 27, 2013 at 7:04 am
    Thanks everyone I guess all I had to do was ask the experts and when I got up this morning they were working properly.
    MAGIC the easiest fix ever.
