  • Entrance Stairs – Air Slide Regulator
    Posted by Dorel on March 9, 2023 at 3:32 pm
    After changing the Aux Compressor Pressure Switch, thought I was done, ready for a cold one…air leak/hissing from under driver area…soap and water bottle handy, sprayed all the had a connection…air slide regulator was leaking…push in the connectors, a little better, but still leaking…
    Released all the air from the system, took the regulator off / apart…inside diaphragm worn out/broke.
    Did some research, no spare parts, regulator discontinued, but replacement available.
    Original R384-01C
    Replacement R374-01C or 14R013FC
    I attached pictures for reference.
    Dorel replied 3 years, 7 months ago 1 Member · 0 Replies
