Engine Oil Mechanical Oil Pressure Gauge Leak
While at the Mini Rally in Everglades City last weekend I took a few minutes to look the engine compartment over for possible oil leaks since I had just washed the engine down before the trip down from Naples. I noticed a little oil moisture in the vacinity of the mechanical oil pressure gauge in the upper right area of the compartment. I got a flashlight for a closer look. When I looked at the gauge it was evident that it was full of oil and that the oil seep was coming from the gauge. The gauge had failed internally and all that was keeping the engine from pumping out and exhausting the oil supply was the integrity of the gauge case and glass. I was horrified. I have seen internal gauge failures in aircraft hydraulic systems when they were exposed to thermal expansion, but never an engine oil pressure gauge. I wouldn’t, and didn’t, start the engine without correcting the problem.
Since that gauge would only be used to varify, or rule out, a possible problem indicated by an electric instrument panel gauge or while doing maintenance on the engine it is not necessary that it be in operation during normal bus use. With that in mind I went to the local Ace Hardware store and purchased a 1/4 inch ball valve and a brass plug. I removed the failed gauge and installed the ball valve in it’s place and the plug in the valve to keep it clean (probably overkill). When I got back to Naples I purchased a gauge and removed the plug and installed it. I started the engine with the valve closed and, just as it should have, the gauge read zero. I opened the valve and it went to 50 lbs. as it should have. I closed the valve and shut down the engine. The gauge continued to read 50 psi until the next day and when I opened the valve again and it went to zero. A good valve. I plan to leave the valve closed taking the gauge out of the system except when it’s needed for maintenance reasons eleminating the possibility of an untimely failure and loss of engine oil.
This may not seem like a very important item to most, but I feel that I discovered a problem, almost by accident, that could have led to a very costly catastrophy. I feel very lucky and that I dodged a very large bullet.
I would be interested to know if anyone else has had this problem.
