  • Engine Lights
    Posted by DON on March 27, 2023 at 3:31 pm
    This weekend,125 miles from home, the check engine light and red “stop” light started flashing on & off. I stopped and determined there was a slow coolant leak above the passenger side tag axle. I couldn’t see the hole. So I shut off 2 (webasto?) ball valves above and fwd of webasto burner, shut off another ball valve near the thermostat housing on driver side, and a gate valve down low on drivers side. Leak stopped leaking. Added 2 gallons of water and finish our drive home. Engine temp never got hot. Took about 15 to fix it and get on the road again.
    Know your systems.
    Dick replied 3 years, 7 months ago 6 Members · 7 Replies
  • 7 Replies
    March 27, 2023 at 4:16 pm
    Great job.
    We need some photos
  • Chuck & Katrina
    March 27, 2023 at 4:32 pm
    I’ll eventually get under the bus a find the leak(s) and change the hose(s). Bus is getting old.
    Leesburg, FL
    March 28, 2023 at 10:01 pm
    Hey Don! Last year I replaced most all the hoses with Silicone hoses, It’s funny all the hoses I Replaced were also Silicone hoses, Didn’t know back then they had silicone hoses, Changed both Thermostats cleaned housing up
  • Unknown Member
    March 29, 2023 at 10:17 am
    Good Morning Art,
    Great job on changing those silicone coolant hoses. It is on my to-do list.
    In what condition did you find the old ones?
    What was your source for the replacement silicone hose?
    THANK YOU!
  • George
    March 30, 2023 at 10:27 am
    https://www.siliconehose.com/account.php?action=order_status
    The hoses were in pretty good shape but a good time to replace this place FlexTech was quick and had every size i needed
    March 31, 2023 at 4:25 pm
    Crawled under today and found the coolant leak, pax side, inside the frame rail, next to the tag bag, two 7/8″ i.d. heavy duty hoses, Marine Products Intl (MPI), where a wire ty is holding them together by who? Preious owner, Prevost, Liberty. Probably original hoses. I knew the day was coming. I’ve had new coolant waiting in the wings for a while now. I’ll be making a list.
    March 31, 2023 at 6:07 pm
    Art:
    The new hoses are pretty. Very pretty.
    Dick
