  • Engine Compartment Light
    Posted by Tim on March 30, 2017 at 6:27 pm
    My 12v light in my engine compartment has never worked since I purchased my Bus. No big deal, since I’ve never really needed it; however, with some time to kill today, I put in a new bulb with negative results.
    So, I then checked the 24v relay, replaced the 24v relay with a 24v relay that I knew was working, and then replaced the 15amp fuse with a 15amp new fuse. Nope.
    On my coach, I don’t have a toggle switch to turn the light on/off. The light is supposed to be activated via magnet when I either open the passenger rear side door or the engine compartment door.
    Anyone have any other ideas?
    Dick replied 9 years, 8 months ago 4 Members · 5 Replies
  • Harry
    March 30, 2017 at 7:02 pm
    Did you have either the key on or the flashers on? On mine the lights don’t work unless one or the other is on.
    March 30, 2017 at 7:18 pm
    Tim, ignition key ON, storage switch by the entrance door ON, it should work, confusing I know…learned that at Prevost QC last summer…did a lot of troubleshooting myself…LOL…
  • Ronald
    March 30, 2017 at 7:54 pm
    Tim,
    Mine works the same as Mark stated plus I have a dash switch labled Work Lights that also turns on my engine and rear bay lights along with the two white lights on the back next to the backup lights.
    3-F
    March 30, 2017 at 8:35 pm
    Thanks All!
    March 31, 2017 at 12:37 pm
    boy, i was really gypped! All I have is a simple switch.
