  • Emergency Brake Air valve PP-1
    Posted by Andre on April 11, 2014 at 4:31 pm
    Ok I have a silly question. I want to replace my emergency brake valve and because of where it is I cannot make out what holds the handle on the valve. It is very hard to see but looks like it might be a roll pin? Anyone know for sure?
    Does it just push out?
    Have a new one on order. Still chasing air leaks but making progress.
    Mark replied 12 years, 7 months ago 5 Members · 4 Replies
  • Mark
    April 11, 2014 at 5:21 pm
    The pin is indeed a roll pin. I turn the knob until I can get a small diameter punch lined up with the pin and tap it with something like a small hammer or anything with a little weight. The pin will push right out.
    April 11, 2014 at 9:35 pm
    Thanks, looked like a roll pin, just could not be sure. Trying to be carefull.
    April 11, 2014 at 10:21 pm
    Andre a lot of the new ones don’t have roll pins they have a spring pin just push it in and off it comes. The older ones have a roll pin just use small punch and it comes out .
  • Mark
    April 12, 2014 at 10:19 am
    Peter,
    Thanks, looks like the valve is the orginal one that came with the bus and it has a roll pin. The new one will be here Monday and I will see if it has a sping pin.
