Thanks for pointing that out, Mike. I initially wanted to use all stainless steel parts, but shifted to all zinc-plated parts due to cost. I had some concern about potential corrosion when the guy at McMaster-Carr suggested the stainless steel substitution for the back-ordered turnbuckle rod, but I thought that was more of a long-term concern. I did some reading last night about galling and galvanic corrosion. I’m starting to suspect that the issue I had with the threads may actually have been galling. The stainless steel rod and zinc-plated female coupler certainly locked together, taking maximum effort to separate them with severely-damaged threads. Really, it took almost all my strength with a 12″ long wrench and a bench vise. It doesn’t make sense to me now that bad tolerances on the threads would have caused that when I used very little effort when threading them together.
I found a shorter jack screw/turnbuckle rod that will still work. The eBay listing doesn’t mention it, but I think it’s a yellow zinc coating. I found other sites that seem to have the same part with a better description. I’ll just need to cut a longer piece of threaded rod to make up for the lost length. As a benefit, this piece has 3/4″ hex flats, so the 1/2″ wrench won’t be necessary anymore.
Yes, Never ever use stainless on stainless. I learned that many years ago, and regardless of what it says on the bottle, no anti seize works.
Just to clarify, the turnbuckle rod with LH and RH male threads is the only stainless steel part. Everything else is zinc-plated steel. With this new part on the way, there will be no stainless steel in the assembly.
I think you will be good to go with that. Get out the shaker can and live life to the fullest!
Okay, I reassembled the tensioner using the new turnbuckle rod. The rod I originally wanted to use was threaded 2″ on each end. This new rod is only threaded 1 1/2″ on each end. That effectively reduces my range of adjustment by 1″. I was concerned about that, but I have since determined that I really only need an adjustment range of about 1 1/8″ to go from very taught belts to loose enough to easily change them.
The adjustment range is calculated by taking the length of the threads (1 1/2″ + 1 1/2″) and then subtracting the thickness of the jam nuts (5/16″ +5/16″) and the length of threaded rod you always want to remain engaged in the mated parts. I was shooting for at least 1/2″ engagement of the threads when the tensioner was fully extended. I ended up leaving a bit more (5/8″) engaged on each end. That feels very solid with the 1/2″-20 threads.
1 1/2″ + 1 1/2″ – 5/16″ – 5/16″ – 5/8″ – 5/8″ = 1 1/8″ range
All parts are now zinc-plated steel, with the turnbuckle rod being yellow zinc. I did throw a different cotter pin in at the yoke end, and cadmium plated is all I had on hand. I think that’ll be okay, but it’s easy enough to swap out.
I timed myself replacing all three fan belts at a relaxed pace. It took three and a half minutes. I’m calling this one a success!
Chad, that looks a whole lot simpler than what you started with. Glad you pushed that project over the finish line.
