  • Electric shades
    Posted by Cliff on December 20, 2015 at 1:20 pm
    I am trying to figure out why one of my electric shades does not function. I’ll start by saying it is a ’99 Vantare H3. Of coarse, it is the one tucked up behind the cupboards in the galley! I have pulled the (triple) switch out and checked the switch, which works fine. I even jumpered a known good switch to varify it was not the switch. My question now is, where do I go from here? I can see two screws holding the assembly up in place but am afraid to remove them because I don’t know what is behind there. Any help will be much appreciated. Thanks, Cliff
    Archived replied 10 years, 10 months ago 9 Members · 8 Replies
  • 8 Replies
    December 20, 2015 at 2:44 pm
    Cliff, go ahead and remove the screws and undernearh you’ll find another…then the shade unit should come down and give you access to the motor. Geo.
    December 20, 2015 at 5:33 pm
    Thanks George. I’ll try it in the morning and let you know how I come out.
  • Karl
    December 20, 2015 at 8:36 pm
    Thanks for the offer, I may be getting back to you. Cliff
  • Tom
    December 21, 2015 at 8:21 pm
    Well, I’ve tried everyting I could imagine and still no luck. I can’t get the shade down =( I took the two screws out that hold the piece that the shade is attached to but it won’t come down. Then, I released the three brackets that hold the shade and the shade won’t come down. I have no idea what the assembly looks like so it makes it harder to figure it out. Does anyone have a picture or drawing or anything that shows me what it looks like? Thanks, Cliff
  • Rudy
    January 1, 2016 at 4:18 pm
    So, after talking with Ed, I now have my shade in my hand. My question is, to test it, do I just hook up 12V to the two wires, or is that not the correct way to test? I did that and nothing happend. I found the new motor on line but want to make sure I’m testing it correctly. It is a 12V, Somfy motor, number LT28-A73.Thanks, Cliff
    January 2, 2016 at 7:02 am
    Are you sure it is a 12 volt, or even a 24? On my previous coach my shades were 120. I don’t know what my current shades are.
    January 2, 2016 at 9:47 am
    The shades on my Liberty (motor) were 24v, the ones on my Marathon are 12v. To test, just reverse the wires for up and down.
    January 2, 2016 at 10:35 am
    It says 12V on the motor. I have connected 12V in both directions and it makes no sound at all, should I assume it is the motor? Thanks, Cliff
