EGR coolant hose
This might be a coincidence or it could be a potential problem for all EGR equipped coaches, especially those in the 10+ year range.
I had a hose leak at what appeared to be at the upper hose clamp where the rubber coolant elbow (053696) attaches to the EGR intercooler and re-tightening the clamp appeared to solve the problem. However after about 200 miles I had a catastrophic failure and Prevost service had to come to the coach to make the on-road repair.
Now another member with a similar age coach is experiencing a leak at the same clamp at the same hose elbow.
I would urge all owners of early model EGR equipped coaches, and maybe high mileage EGR coaches to pay close attention to the hose on the bottom of the EGR intercoolers. It is very difficult to see, but it is at the lower left side of the engine where several large diameter coolant pipes are located. If you see any coolant dripping from that area, or if you see evidence of a leak such as a dried haze on the rear of the coach or toad, or if you note the coolant level has gone down I suggest you immediately take the coach in for repairs and hose replacement. If this is a problem that is going to be common to our coaches a clamp tightening is not going to fix the problem but may only temporarily delay it. The repair involves draining all coolant for hose replacement.
