  • ECM Battery Replacement
    Posted by Larry on October 19, 2021 at 12:49 pm
    Does anyone know if the 3.5 Volt battery inside the ECM is case positive or case negative. Don’t want to remove the ECM twice just to check it before I order the battery. Two versions of the same battery are available so just though someone else might have undertaken this task before.
    https://www.eaglepicher.com/sites/default/files/ltc-7pn.pdf
    Jonathan replied 5 years ago 5 Members · 4 Replies
    October 21, 2021 at 10:21 am
    Don’t know and wonder how many have to replace the battery. Sold my coach a couple months back and ECM battery was 30 years old. Never had to replace and never any problems. . I’d call Prevost Service and think they would tell you.
  • Jonathan
    October 21, 2021 at 3:33 pm
    You have a series 60 call a Detroit diesel dealer ,see what they say .
  • Chad
    October 22, 2021 at 3:15 am
    Thanks guys…
    1984 96" with 8V92TA
    (remodeled Liberty Coach)
    Greenwood, MO
  • Marshall
    October 22, 2021 at 2:23 pm
    I’d suspect it to be case negative. Easiest way to avoid mismatch might be to order both types.
