  • Drive axle hub seal
    Posted by Alex on August 23, 2022 at 4:07 pm
    Has anyone changed the inner hub seal on a drive axle with disk brakes? I am having issues getting the hub to separate from the rotor on my H3. Can’t get the hex bolts to move. I am hesitant to use a torch while connected, and the only way to pull it off as a complete assembly would to remove the brake caliper and mounting bracket (which I would like to avoid if possible) Any thoughts? Picture attached.
    thanks
    Alex
    Alex replied 4 years, 2 months ago 1 Member · 0 Replies
