  • Door handle lights and window accent lights
    Posted by Dorel on June 8, 2015 at 11:45 am
    Hello, entry door outside light and inside handles do not light up, where do I start ?
    Also all windows accent(rope lights) are missing bulbs, how do I replace them? Rope lights from Vista? 12V?
    tHANKS
    Dorel replied 11 years, 5 months ago 7 Members · 9 Replies
  • 9 Replies
    June 8, 2015 at 11:51 am
    Inside the handles there is just a wire with led’s on it, no tube
    June 8, 2015 at 2:29 pm
    My Royale uses “Illumagrip”. ( http://www.itc-rv.com/product-category/assist-handles/ ) Mine does not look exactly like yours, but maybe a different model.
    Replacement LEDs are available.
    June 8, 2015 at 5:17 pm
    Thanks John. Mine it has 2 holes/channels approx 3/8 dia, with couple wires/bulbs attached running thru.
    June 8, 2015 at 7:15 pm
    The bulbs are in the wires…..
    If all three items are out plus others in behind steps not pictured I would suspect the fuse for entry lights. Located behind upper panel passenger side above entry steps ceiling bulk head.
    There is a fuse block ….. if you see a red light “on” that’s the fuse to replace.
    Usually the cause of blown fuse is the entry hand rail mounted on dash wall. The wires are not well protected and over time rub inside the pipe on edge going around corner inside pipe.
    Repair with black tape separating each wrapping securely to prevent shorting. That handle is a PIA to remove and reinstall as there is a plate behind that must be installed back correctly for strength .
  • Dewey and Tina
    June 8, 2015 at 8:08 pm
    Dorel,
    Under the top hinge on mine there is a very small black rocker switch that is hard to see that turns on the lights. Just a thought in case you missed it.
    June 9, 2015 at 11:11 am
    Al, Tom, thanks. could see a red light behind this panel, there is where i heard the click when resetting by the door hinge with no action. Not sure yet what Greed / Red means on this coach, on/off, but i am learning as i go, appreciate your input. I will let you know.(btw, just fyi, web is responding very slow when typing..)
    June 9, 2015 at 12:11 pm
    D&C
    Web not slow, just smart. It knows that Tom and Big Al can’t read very fast, so it is just typing at the speed that they can read.
    3F
    June 9, 2015 at 2:34 pm
    Thanks…good to know, all the help is appreciated..
  • Dorel
    June 15, 2015 at 11:29 am
    AL, checked this weekend, no red light, I attached couple photos, thanks for your input.
    Above door, there is a fuse block, i took off last weekend, no red lights…
