  • Door and Drawer Latch Lubricant
    Posted by Dewey and Tina on June 8, 2015 at 6:32 am
    Looking for suggestions on the best lubricant to use on door/drawer latches inside and out… I am sure it is listed here somewhere but I have not been able to find it.
    THANKS, Dewey
    Rocky And Tonya replied 7 years, 8 months ago 13 Members · 16 Replies
  • 16 Replies
  • Dewey and Tina
    June 8, 2015 at 7:00 am
    The only lube I have ever used on door or drawer latches was the occasional lube on the pins that lock the bay doors. Specifically what latches do you think will need a lube? Can you post a photo?
  • Bryan
    June 8, 2015 at 7:08 am
    Just looking at simple preventive maintenance on exterior bay doors, sewer tube doors, etc.
    interior black latches for the drawers and closet doors… regular WD40 seems to collect the dirt and gum everything up.
    THANKS, Dewey
    June 8, 2015 at 8:57 am
    I have found over many years to use spray silicone. Does not collect dirt as does WD40. Interestingly enough, Zipdee notes to only use silicone on all its awning parts.
    June 8, 2015 at 9:26 am
    I don’t put anything on the Southco door and drawer latches.
    The only lube I do on bay doors I mentioned above.
    The latch on the Liberty sewer hose storage on XL coaches is a problem area and you are damned if you do and damned if you don’t. It collects grit, dirt, sand etc from the road. If you lube it it gets more crud collected on it. If you don’t lube it it gets corroded.
    I found on those touch latches to just operate them often and if necessary remove them and clean the dirt and corrosion from them. I carried a spare.
    With the exception of the bay door locking pins if it does not have a grease fitting I do not lube it.
    June 8, 2015 at 1:47 pm
    Silicon spray on the bay door locking pins?
    June 8, 2015 at 4:34 pm
    That or a dry teflon was what I used. WD40 or equivalent eventually seems to get a lot of grit on the pin and slide.
    June 8, 2015 at 5:08 pm
    Don’t get silicone on any surface you may need to paint later.
  • Sid
    June 8, 2015 at 5:27 pm
    I’m pretty sure I will not ever be painting my stainless.
    June 8, 2015 at 6:04 pm
    Me neither but spay can silicone will end up on painted surfaces far from where its sprayed. I have done a fair bit of car painting as well and know first hand that it is diffcult to paint over. Just saying be careful.
    June 8, 2015 at 6:35 pm
    Good reminder Gary. But I’m as likely to paint my stainless as I am to put that stinkin’ DEF in my coach.
  • Miles
    June 9, 2015 at 6:24 am
    Thanks for the info… yes; we have found that extra parts are always in order
  • Jeff
    March 10, 2019 at 2:43 pm
    Jon:
    What is the correct part number that you have previously told is to stock up for drawer and door latches? Also where can we order them from? I’ve ordered numerous from Amazon but they are all too large. Thanks. Scott Reising.
    March 10, 2019 at 7:50 pm
    Scott,
    If you don’t find them let me know, I may have a few in the archives. I’m sure Jeff buys them in bulk and could bring to Oysterfest.
    March 10, 2019 at 8:05 pm
    Dry graphite spray lubricant is more slippery then WD40 or silicone spray, and attracts/ collects residue less.
  • Rocky And Tonya
    March 11, 2019 at 8:25 am
    Scott,
    Southco is the manufacturer and the latches common on a lot of coaches come in a variety of mounting styles and strengths.
    https://www.southco.com/en-us/c3
    I have seen them at a variety of internet sites so if you can’t buy direct you should be able to find them elsewhere like ebay or Amazon.
