  • Dometic control did not control HVAC
    Posted by George on October 21, 2022 at 9:32 pm
    Strange events
    no function on dometic control would function
    Reset dometic by holding top and bottom buttons turn on the on off switch
    display showed FF
    the fan and heat pump started to work but the AC units were blowing cold air not heat
    Furnace would not bring on any of the three zones
    Removed aquahot cover and can bring on all three zones y shorting to ground
    question why control will not start zones
    Roscoeapproved replied 4 years ago 3 Members · 2 Replies
  • Dave
    October 22, 2022 at 9:47 am
    On my coleman you can only go 4 degrees at a time. If you try to go more than the 4 degrees it tries to turn on the gas heat. I don’t have gas heat so when it is cold I just move the setting by the 4 degrees.
  • Roscoeapproved
    October 22, 2022 at 9:58 am
    Check underneath wiring, When they removed your AC’s maybe they forgot to connect the Blue wire,That sends 12v to heat be it a furnace or Aqua Hot, It send 12v to heat source,a furnace it activates it on a older Aqua Hot the 12v goes to 3 cube relays that changes a 12v signal to a negative signal. After 2003 newer Aqua Hot units with control boards the 12v signal turns it on. You have a cube relay for each zone Bedroom/Bathroom/living room. Here is a Royale wiring schematic for your model and year. See 4 cube relays extra one for Bay Heat, Those cubes are right near Aqua Hot same compartment
    Jeff and Lindsay
    91 Marathon XL
