Dock / Storage power getting 2 legs out of it
Okay, I have this thing stuffed over in the enclosed storage nearby … I’ve got it plugged into 120v via an adaptor that goes 15a->30a->50a basically one leg L1(A) of the AC is getting power. One of the trace inverters (A) is showing green/green so its got a full charge on that bank. The other inverter (B) is yellow only. Discharging. There’s no load on this leg according to the meter.
I’m concerned that some portion of the house batteries are slowly discharging with just the inverter load, even idle .. that the A side isn’t going to charge that, or there is some switch somewhere that I need to throw to combine the two legs for the purpose of storage. (having no conversion manual is really a PIA)
In the hopes that there’s a simple solution to this, I bought one of these: http://www.campingworld.com/shopping/item/50-amp-rv-box-adapter/25774 But without knowing before hand to look at the storage building, the city code requires these dock power systems on GFI, which the little box above will create a slight phase imbalance which (of course) will pop the GFIs on both legs. I can fix this by buying a pair of 120v-120v isolation transformers and a little clever wring, but I’m not sure thats thats the right answer. (removing the GFis isn’t an option though I considered some midnight rewiring when noone was looking to move the load around on them)
Thoughts?
