  • DIY Front Disc Pads, Inner Oil Seals, etc
    Posted by DON on December 29, 2022 at 7:31 pm
    My front disc brake slide pins were sticking out past the boss less than .250″. When new the pin sticks out about .625. Mx manual section 12 page 17 &18 says to pull the wheel and inspect, So, that’s what I did. The inner pad had about .200″ of fiction material remaining. When new it has .910″. The outer had .300″ remaining. When new it has .570″.
    Since these Rockwell/Meritor disc brakes are a single (inner) piston design, the inner pad wears much faster than the outer. That’s why the inner pad is so much thicker than the outer when new.
    While I had the caliper off:
    Also removed hub/rotor
    cleaned bearings, slide pins, bushings, replaced o-rings on pins
    Lubed caliper, slide pin, bushings, slack adjuster, tie rod, king pin
    Changed frt right inner oil seal w/Scotseal SKF # 35066 = Prevost# 610870
    Changed outer gear oil hubcap w/Road King 343-4024 = Stemco 343-4024 = Prevost# 611252
    replaced brake pads w/new – Meritor# KIT15615PM or SR27017173 per wheel, or Meritor# KIT15625 per axle.
    replenished gearoil with Amsoil SVG 75w-90
    reassembled everything
    set wheel bearing pre-load/end play to .002”
    adjusted brake
    torqued lugs nuts 450 ft lbs
    Test drove it
    Will do the same to the left front soon. Drive and tag axle brakes still have plenty of meat.
    Don’t tackle this job if you don’t like getting dirty 🙂
    Dick replied 3 years, 10 months ago 9 Members · 9 Replies
  • 9 Replies
  • Jamey
    December 29, 2022 at 7:43 pm
    2 fingers worth of wear, or 1″. Piston has to be adjusted all the way back in so the new pads will fit over the caliper.
    December 30, 2022 at 11:29 am
    My index finger points at the poppet
    My middle finger at the pawl
    My thumb at the adjuster
    Per the mx manual on how to grease the calipers, adjust the brake, and check for proper automatic slack adjuster operation:
    a) remove the caliper poppet fitting that’s located half way between the 2 grease fittings.
    b) pump Meritor pt# A1779W283, NLGI#1 grease, into the 2 grease fittings until fresh grease comes out the poppet fitting hole.
    *****Have the front wheels chocked, have enough air in the brake tanks and release the parking/spring brakes*****
    c) release the pawl (hold it out) on the slack adjuster and adjust or loosen it(cw=lengthen stroke) fully which is about 4 or 5 360 turns of the adjuster on the end of the slack adjuster. This will force excess grease out of the poppet fitting hole.
    d) reinstall the poppet valve/fitting
    e) re tighten(ccw=shorten stroke) of slack adjuster fully until pads are clamping the rotor, then release the pawl again and loosen/release(cw=lengthen) stroke 1/2 to 3/4 turn.
    f) set parking brake, remove chocks
  • Jon
    December 30, 2022 at 2:27 pm
    Good work Don. Thanks for the detailed photos and explanation, feels like I was there.
  • TRUE
    December 30, 2022 at 3:53 pm
    Thanks Luc,
    Do you feel dirty 🙂
    December 30, 2022 at 4:06 pm
    Ha Ha! I almost said that.
    December 31, 2022 at 11:49 am
    My memory must be terrible. Replaced steer axle pads a year or so ago (Rockwell/Meritor), ordered from Prevost. I don’t remember a thickness difference between inner and outer – but I guess there was. Also don’t remember what looks like a tone ring on the back side of rotor(s). No ABS on mine, guess that was an option back then (95 chassis)?
  • Jack
    December 31, 2022 at 10:21 pm
    My 95 chassis/96 Liberty #331 doesn’t have ABS either, but it may have been an option in 1995.
  • Bernard
    December 31, 2022 at 10:56 pm
    My 92 has the same proximity sensor flags, and i have an ABS dash light that comes on when i turn the key on. I have never tested to see if it works, nor do i plan to.
    January 3, 2023 at 3:20 pm
    Thanks for the write-up Don! I’ll be referencing this later.
