  • Direct TV signal
    Posted by Tony on September 11, 2017 at 3:09 pm
    I have a 1996 XLV that was full of Analog Stuff. I have installed 3 Digital TV’s and a Black Jack Digital Ant. The coach was prewired with RG 59 with no way to easily pull new RG 6. My HD ant is providing a great picture and the Direct TV is good in the back which close to the Sat Antenna, but the front salon TV 45 ft way is a little grainy. Should I install a powered amplifier? Any Ideas ?? What woiuld you do?? thanks
    Archived replied 9 years, 1 month ago 3 Members · 2 Replies
    September 11, 2017 at 5:09 pm
    Tony,
    I installed a wireless HDMI in the rear of my 01 Liberty for the front TV and it worked well.
    September 12, 2017 at 11:37 am
    Tony I am using the following equipment,
    IOGEAR Wireless 3D Digital Kit with Full HD 1080P and 5.1 Channel Digital Audio, GW3DHDKIT. Has a 100 foot range thru walls and ceilings. Device is under $2000.
    i have had nothing but the best experience with this equipment. I am sending my Blue Ray/DVD signal from back of bus to front. No issues with this setup at all. I even use a Slingbox . You can run two different signals thru this device. Sure beats trying to install any wiring.
