  • Difusers for air conditoner
    Posted by George on September 14, 2019 at 5:16 pm
    I found a stack of these in the cabinet and discovered by accident one in the overhead vent.
    I assume they are supposed to be in al the vents but were removed for some reason
    Comments
    Corey replied 7 years, 1 month ago 2 Members · 1 Reply
  • 1 Reply
    September 14, 2019 at 7:56 pm
    Those are used to diffuse and direct the air from the roof top A/C units.They are not absolutely needed but they do help spread the cold air out some. If you look at the opening in the ceiling where the one that is installed, you will see 2 little clips that hold it in place. Look around and you should be able to find the other clips to show you where the other plate goes.
