  • Detroit power cool mixed with power cool Plus
    Posted by Chuck & Katrina on January 27, 2024 at 8:01 pm
    Had Detroit Power Cool PLUS in my engine. Had Prevost flush and refill the system, BUT they put Power Cool back in the system and not Power Cool PLUS as I requested.
    Have a couple of gallons of Power Cool Plus left over, can I top off (mix) the coolant tank with Power Cool Plus on top of the Power Cool that is currently in the system.
    Chuck
    Leesburg, FL
    Chuck & Katrina replied 2 years, 9 months ago 4 Members · 4 Replies
  • Jon
    January 27, 2024 at 8:18 pm
    Incompatible formulas.
    Needs to be THOROUGHLY flushed.
    ***Your coolant filter is likely wrong now also. It should always be a “blank” filter for OAT coolant. I.e., contain NO supplemental coolant additives
  • Tom
    January 28, 2024 at 10:18 am
    If the two technologies are mixed it appears the only downside is the coolant now has a 2 year life, instead of an extended life. If a blank coolant conditioner was used and is still in place, replace it with one that adds SCAs over time.
  • justin
    January 28, 2024 at 10:49 am
    I had researched this issue in the past when trying to help inform another friend.
    I just now googled “what happens when mix sca coolant with oat coolant” and this is the first result:
    (all state the same)
    Never Mix OAT with Regular Coolant
  • Chuck & Katrina
    January 28, 2024 at 8:06 pm
    Thanks for the input. Will not attempt to mix.
    To clarify, had extended life Power Cool Plus. Prevost removed, flushed and refilled with just Power Cool.
    Went from extended life to basic 2 year protection. Not happy about it. Specifically ask for the Power Cool Plus and not the regular Power Cool. Guess you don’t always get what you ask for…
    Chuck
    Leesburg, FL
