Detroit monitor
Posted by George on October 29, 2019 at 2:18 pmstarted on trip Sunday and no indication on Detroit Pro monitor
same today when I left coming home
any thoughts
Chuck & Katrina replied 6 years, 10 months ago 10 Members · 9 Replies -
There is an inline fuse for mine in the steer compartment, that had blown on mine once before, put a new fuse in and it was up and running.
Looked for online fuse to no avail
can you post picture of inline fuse you found
I’ll try and get over to the coach and get a picture in the next couple of days.
My Detroit Pro Driver is dark. I too will be looking for the fuse. Thanks, Darrell
gmjdw Did you find the fuse to the Detroit Pro Driver ?
Leesburg, FL -
found the problem with my detroit pro driver. Circuit breaker #2 inside passenger side engine compartment door near the 12/24volt cut off switch. reset red button.
Deleted User
Deleted UserDecember 28, 2019 at 7:31 pmHave not reset any breakers but today coming back from Myrtle Beach it was working great. When I restated after putting it in shelter it came up perfectly.
Still trying to determine cause for not working on last three time starting bus
Intermittent problems can drive an owner nuts. Usually an intermittent problem can be traced to a poor connection, usually a ground. But sometimes it is best to just wait until something quits entirely because chasing a problem that doesn’t exist at the time is frustrating.
